IIS3DWB values in OUTX_H_A, OUTY_H_A, and OUTZ_H_A sometimes double what they should be
WPost.1
We are using the IIS3DWB eval board and noticed that occasionally the values in at least one of the output registers are double what they should be while the accelerometer is at rest in 8g mode. This happens with BDU on and even when the status flag is checked before retrieving data and when reading from the FIFO. example of output data:
|At 1673363677710ms
|X: 4 |Y: -9 |Z: -15
|resulting vector: 17
|At 1673363677760ms
|X: 4 |Y: -5 |Z: -15
|resulting vector: 16
|At 1673363677811ms
|X: 4 |Y: -7 |Z: -16
|At 1673363677862ms
|X: 4 |Y: -4 |Z: -16
|At 1673363677913ms
|X: 4 |Y: -4 |Z: -16
|At 1673363677963ms
|X: 4 |Y: -4 |Z: -15
|At 1673363678014ms
|X: 4 |Y: -4 |Z: -15
|At 1673363678065ms
|X: 4 |Y: -6 |Z: -30
|resulting vector: 30
With no movement the OUTZ_H_A register doubles, this has been observed in every register at different times/orientations of the accelerometer. Below is the init sequence in C++
#define IIS3DWB_CTRL1_XL        0x10
#define IIS3DWB_FIFO_CTRL4      0x0A
#define IIS3DWB_CTRL8_XL        0x17
#define IIS3DWB_CTRL3_C         0x12
#define IIS3DWB_STATUS_REG      0x9E
#define IIS3DWB_OUTX_H_XL       0xA9
#define IIS3DWB_OUTY_H_XL       0xAB
#define IIS3DWB_OUTZ_H_XL       0xAD
#define powerDown               0x0C
#define startUp                 0xAC
#define fifoOff                 0x00
#define lowPass                 0x00
#define BDUenable               0x44
#define sw_reset                0x01
   //initial startup 10Mhz SPI mode 3
   result = lgSpiOpen(0, 0, 10000000, 3);
   usleep(10000);
   //reset software
   txBuffer[0] = IIS3DWB_CTRL3_C;
   txBuffer[1] = sw_reset;
   fd = lgSpiWrite(result, txBuffer, 2);
   //power down accel
   txBuffer[0] = IIS3DWB_CTRL1_XL;
   txBuffer[1] = powerDown;
   //shut fifo off
   txBuffer[0] = IIS3DWB_FIFO_CTRL4;
   txBuffer[1] = fifoOff;
   //enable lowpass filter 6.3khz
   txBuffer[0] = IIS3DWB_CTRL8_XL;
   txBuffer[1] = lowPass;
   //enableBDU
   txBuffer[1] = BDUenable;
   //start back up with +/-8g mode, all other defaults
   txBuffer[1] = startUp;
and the init sequence when trying with the fifo:
   //reset software
   //power down accel
   //shut fifo off
   //enable fifo in continous mode
   txBuffer[1] = continuousMode;
   //set data rate for fifo
   txBuffer[0] = IIS3DWB_FIFO_CTRL3;
   txBuffer[1] = batchDataRate;
   //set watermark to 1
   txBuffer[0] = IIS3DWB_FIFO_CTRL1;
   txBuffer[1] = watermark1;
   //set fifo depth to watermark
   txBuffer[0] = IIS3DWB_FIFO_CTRL2;
   txBuffer[1] = watermark2;
1 REPLY 1
Eleon BORLINI
Hi @WPost.1​ ,
are you acquiring the data at a proper SPI speed? Remember that the ODR of the IIS3DWB device is 26.67kHz.
-Eleon
