2020-11-03 03:04 AM
a customer is asking for details regarding the part-marking of P/N: HTS221TR .
Would you have an outline or scheme which explains the marking details?
Thank you.
Bet regards
Adnan
2020-11-03 03:30 AM
Hi @AZata.2393 ,
The top package should appear as follows:
The meaningful data is the alphanumeric code you should see near the dot (not so easy to be seen, indeed, you might tilt the device below the microscope to see it).
Here the meaning:
-Eleon
2020-11-03 03:30 AM
Hi @AZata.2393 ,
Here the meaning:
-Eleon
