2021-07-31 01:37 AM
2021-08-02 08:09 AM
it works now : there was a bit to set in the TAP-CFG register of the LSM6DS3TR-C, in order to activate all the interrupts (bit which doesn't exist in the LSM6DS3).
anyway, thanks for your help !
Best regards
Olivier
2021-08-02 08:02 AM
Hi, did you tried configuring the interrupt in open-drain? Note that registers can vary a little so that also the configuration code has to be checked.
Tom
2021-08-02 08:09 AM
Best regards
Olivier
2021-08-02 11:31 PM
Thank you Oliver for having shared your solution!
-Eleon
