2019-05-07 06:40 PM
We’ve just announced the launch of a new sensor unit called SensorTile.box. It is a flexible IoT Plug and Play module to jumpstart sensor-to-cloud IoT applications.
Find out what you can do with the SensorTile.box by reading our blogpost at https://blog.st.com/sensortile-box-sensor/
Grab yours to get started!
Follow this new topic! More to come ...
2019-06-18 03:37 AM
I just got one sensorTile.box. How can I connect it to a PC (Window 10 based) for downloading sensor's data?
David
2019-06-18 08:14 AM
Hi David, when you select an App from your smartphone, after the automatic downloading of the FW on the SensorTile.box you can select Start logging and then send you a mail with the datalog attached. You can also select the Data recorder app and that enables you to download of the data stream on your PC by USB cable or Bluetooth. Regards
2019-06-18 08:27 AM
2019-06-18 08:29 AM
You can download the app from here (STBLESensor). Regards
2019-06-18 08:31 AM
2019-06-18 08:42 AM
2019-06-18 08:53 AM
You could interface the box directly from your PC using the Unicleo-GUI - and related SW and HW. However, the related FW is not publicly ready now but will be soon available. Regards
2019-06-18 08:58 AM
2019-07-28 07:17 PM
Hi @Eleon BORLINI is the FW soon to be released?
