2023-10-03 4:29 AM
Hi, I was wondering what is the SR03 settings in initialization of VL6180X ToF sensor? I had gone through the user manual & application note AN4545 but i couldn't get the answer. If someone knows please explain. It just for educational purpose only.
Thanks in Advance,
AK.
2023-10-09 12:41 AM
During the initialization phase, some registers are configured in order to put the sensor in a state that will give the better ranging results. The recommended settings required to be loaded onto the VL6180X during the
initialization of the device is this "Standard Ranging (SR)" configuration defined in section 9 of the AN4545.
