VL6180 GPIO0 / CE and IIC Address Change
Brian_Azzopardi
Hello all,
We have multiple VL6180 sensors on a common IIC bus.
Upon system start up, we are enabling one sensor via its GPIO0 / CE pin, initialising it, changing its IIC address, disabling it, and repeating these steps for all sensors on the IIC bus.
We noticed that upon disabling the chips (GPIO0 / CE pin low) and enabling them again (GPIO0 / CE pin high) to take measurements, their address changes again to the default (0x29) and we cannot communicate with them using the newly-assigned addresses.
Moreover, the sensors would need to be re-initialised before measurement (using the default address).
So am I correct in saying that when low, the GPIO / CE pin completely shuts down the chip and any set registers (e.g. register 0x212 that holds the IIC address) are reset to their default address? Do you have to keep the chips enabled (GPIO / CE pin high) after address is changed?
Thanks for your input!
Brian
Brian
RSO (RDI) at the University of Malta Department of Electronic Systems Engineering
John E KVAM
Exactly -
Your description of how to re-address the sensors is perfect, up until you disable them. Skip that bit.
Once the addresses are changed, they should be very low power. So, enable one, change its address and enable the next and change its address. Repeat as often as you have chips.
If you change all the address, you can occasionally query the original address (0x29). If any of the chips have lost power and rebooted - they will have gone back to that original address.
- john
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
2 REPLIES 2
John E KVAM
Exactly -
- john
Many thanks @John E KVAM !
Brian
Brian
