VL53L4CX meaning of CalibrationData
YChen.9
I would like to know the meaning of each data in the L4CX calibration data(VL53LX_CalibrationData_t in API), because there is a lot of data for this IC, and I would like to confirm the status of the calibration from the data.
Thank you.
Hello
You can consider them as not important values.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
3 REPLIES 3
Anne BIGOT
Did you have a look to the UM2923
Do you need more information ?
Best regards
Hi, Anne
Yes, I found a part of the notes from the manual, but I don't think it's very detailed. There are some values  not defined. So I would like to know the meaning of  all values.
Or are those undefined values unimportant?
Thank you
Hello
