Calibration card
pretoriandave
Calibration of ToF sensors requires a target which is '17% reflective'. Can I take it this means a simple peice of paper or card printed on a laser printer at 83% black (greyscale)?
John E KVAM
No - you cannot use a printed sheet.
Turns out printer ink is a dye - and does NOT affect the reflectance of the paper. 940nm light goes right though dyes.
You need paint.
The best way to go, is to use spray paint. Dark gray should do it. On cardboard. At least 3 coats.
A white sheet of paper is 88% reflective.
A bit of cardboard is about 50%. Your hand is also about 50%.
The blackest flat black spray paint is 5% reflective.
So to approximate 17%, you need a dark gray paint.
The calibration does NOT have to be exactly 17%.
A reasonably dark gray paint should be just fine.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
John E KVAM
You need paint.
pretoriandave
Many thanks John. I had my doubts as to whether it could be as simple as printing onto paper.
Great service, as ever!
