Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
VL53L7CX MTBF
Hi There, Do you have MTBF number for VL53L7CX?   Best regards, Peter
PSO by Associate
  • 840 Views
  • 1 replies
How to decode serial data from VL53L8CH?
Hello,I am trying to get histograms off of the VL53L8CH sensor. I have the sensor hooked up to an F401 and I'm using the official driver from here: https://www.st.com/en/embedded-software/stsw-img043.html.When I start ranging with the sensor through ...
Resolved! Setting up X-NUCLEO-53L5A1
Hi, I have X_NUCLEO-53L5A1 expansion board. I connected this board to ESP8266 inorder to use the VL53L5CX sensor. But the sensor is not being detected.#include <Wire.h> void setup() { Serial.begin(115200); Wire.begin(4, 5); // GPIO4 (SDA), GPIO...
Resolved! Can't Read Data from VL53L8CX using STM32
Hallo Everyone,I am currently trying to retrieve data from a VL53L8CX time-of-flight distance sensor using a NUCLEO-F401RE and an X-NUCLEO-53L8A1 on STM32CubeIDE with the VL53L8CX API. However, I am struggling to get it working and have no idea what ...
gil_B by Associate II
  • 1619 Views
  • 3 replies
  • 1 kudos
Resolved! Detection thresholds in VL53L8CX
Hi Team,We would like to know how the detection threshold works . There will be 16 detection threshold for 16 blocks (4x4 sensor) . Will the interrupt be fired when any one of the threshold is met or all the 16 blocks detection threshold is met ?Plea...
Vbala.1 by Associate II
  • 945 Views
  • 1 replies
  • 1 kudos
Resolved! VL53L4CD configuration and minimum distance reading
Hi to all.I'm trying the VL53L4CD nucleo expansion board. My goal is to use this ToF sensor to detect a very small change in  distace, starting from about 5 mm.The idea is use this VL53L4CD  sensor to detect if the distace become greater than 5mm. (5...
TheRaprus by Associate III
  • 1072 Views
  • 1 replies
  • 1 kudos
Resolved! VL53L4CD Interrupts
HiI am using VL53L4CD for detecting presence of an object at a distance below 300mm. I have considered Examnple4 Ultra Low Power as the base. I am able to get the interrupts when an object comes below 300mm distance as expected.But in this scenario i...
pthakkar by Associate II
  • 3593 Views
  • 9 replies
