About Drivers (C code and reference Linux® drivers) of VL53L5CX
2023-06-22 5:04 PM
"2.1 Software Interface" in the VL53L5CX datasheet states that the driver (C code, reference Linux® driver) is delivered.
How can I get this driver?
Please let me know if there is a download URL for the source code.
- Labels:
Time of flight
2023-06-26 1:12 AM
All the software packages, can be found in the VL53L5CX page on st.com in the "Tools and software" section : VL53L5CX - Time-of-Flight 8x8 multizone ranging sensor with wide field of view (ToF) - STMicroelectronics
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
2023-06-26 1:12 AM
2023-06-27 8:13 PM
I understood your answer.
Thank you your support.
2024-01-04 2:56 AM
Hi Anne,
If I browse to the corresponding link "Get Software" at "Linux Driver for VL53L5CX multi-zone sensor" STSW-IMG025 - Linux driver for VL53L5CX multi-zone sensor - STMicroelectronics there is "no data available in the table".
Seems like the download link is NOT available. Could you please recheck and provide the link to the Linux driver package?
2024-01-04 9:54 AM
Thanks for the alert. It appears someone got something wrong. Give us a few days and we promise to fix it.
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
2024-01-17 1:18 AM
Hi John,
a few days have passed and there is still no Linux driver offered for VL53L5CX at https://www.st.com/en/embedded-software/stsw-img025.html#overview :slightly_frowning_face:. Could you please raise the priority to fix that? Is there an alternative way to get to the driver sources?
Thanks + regards
2024-01-17 2:47 AM
Hello
It has been fixed and should be online now.
2024-01-17 4:51 AM
Yes - I can initiate the download now. Thanks a lot!!
