2025-03-27 6:05 AM
Do you have a FDA accession number for the VL53L4CX ToF chip? I can find only the document "VL53L4 IEC 60825-1 CB test certificate (eye safety)" at the attachments and there it isn't noted. Furthermore I guess it is not the same as for the VL53L5CX.
Regards Tobias
2025-03-27 6:37 AM
Hello
You are right the VL53L4CX FDA accession number if different from tje VL53L5CX.
In the case of the VL53L4CX it is : 2120927-000
2025-03-27 6:37 AM
Hello
