2020-09-24 06:29 AM
Hi..
I have soldered a Teseo-LIV3 on a PCB with acces to power and RX/TX and nothing more. I read the NMEA strings, but no satellite data is present.
Is it correct understood that Teseo-LIV3 can not operate without an external antenna?
If so.....what does "stand alone module" mean?
Kenneth
2020-09-24 06:40 AM
Hi
Any GNSS module on the market needs an antenna.
Please have a look to the HW manual online @ https://www.st.com/resource/en/user_manual/dm00399112-teseoliv3-gnss-module--hardware-manual-stmicroelectronics.pdf
'stand alone' means that IC inside needs just to be powered to be running (flash, TCXO, RTC-Xtal are already there)
Francesco
2020-09-24 06:40 AM
Hi
Francesco
2020-09-24 07:27 AM
OK....
Thank you, I will look into it.
Kenneth
