2023-06-23 01:57 AM - edited 2023-06-23 02:10 AM
I just did a search with "touchgfx language custom container" because text language will not change inside custom containers on the current screen when calling Texts::setLanguage()*. The search engine isn't aware of the existance of TouchGFX and replaces it:
Edit:
* my fault, I use txtLabel.setWildcard(TypedText(id).getText() in the Containers and then there is of course no language information left
2023-07-05 01:25 AM
Legacy message: 2023-06-26 11:40 PM
I have disabled the autocorrect in Search field and the problem should not come up again. Please let me know if it is working for you now.
Thanks,
Lina
2023-06-23 04:36 AM - edited 2023-06-23 05:26 AM
Hello @t.decker,
Just checking if your edit to the post means that the issue has been resolved, or is there still something we can look into?
Thanks,
Amelie
2023-06-25 10:44 PM
Hello @Amelie ACKERMANN,
I found out why the language of my TouchGFX Containers didn't change. But topic of this question was about the search engine replacing the keyword "TouchGFX" with "touched" as you can see in the attached screenshot.
2023-07-05 01:25 AM
Thanks,
Lina
2023-07-05 02:12 AM
yes search is now working as expected. Thank you!
