2017-11-08 5:11 PM
I downloaded the latest SPC5Studio version 5.5. If I check for updates, it looks for
http://spc5.drive.cloudforge.com/projects/spc5releases/spc5studio/updates5
which does not exist. The root branches for SPC5Studio have source for 5.3.2, which leaves me thinking that this way of updating is deprecated? Help>>>Check for Updates... gives error. Anyone available for a retainer, week's worth of work from home to hold my hand a little, please contact me.Solved! Go to Solution.
2017-11-09 12:27 AM
Hello Matthew ,
your update site address is not correct
it is a case sensitive address please use this address in cloudforge
http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio/updates5/
Best regards
Erwan
2017-11-09 12:27 AM
Hello Matthew ,
Best regards
Erwan
2017-11-09 2:15 PM
It looks like the server was down for a bit. I had a corrupt workspace (which is to be expected when you're not being gentle with setting things up). This morning I was able to do a fresh install and all of the updates worked out pretty good. Many thanks Erwan.
