Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Full documentation for SPC560P - DISP?
Posted on March 12, 2015 at 15:35Hello,I need a full documentation for the header I / O of this board (SPC560P - DISP). Is there? The manual on the site of St. explains only the configuration, but not their role. I need connect an LED to a breadboar...
gl2 by Associate III
  • 5551 Views
  • 10 replies
SPC560B-DIS Watchdog Issues
Posted on April 13, 2015 at 11:42Hello,I am currently trying to set up the Watchdog on my SPC560B board.Firstly, after enabling the watchdog and letting it time-out into a reset, it then enters SAFE mode and does not reset the program. RGM.DERD is s...
jleech92 by Associate
  • 1438 Views
SPC560D30L3 - ADC states
Posted on March 18, 2015 at 15:55Hello,I am trying to use the ADC driver (ADCD2) for SPC560D30L3 device using Discovery kit (I have replaced SPC560D40 with SPC560D30 MCU). I am trying to implement a state machine using different states of ADC driver...
ssk by Associate II
  • 4384 Views
  • 11 replies
Application Configuration - Clock settings
Posted on April 25, 2015 at 13:58I am using test application for serial interface with SPC560D30. I used the application configuration - clock settings as 16MHz with the SPC discovery kit. Now keeping the test application same, I want to change the ...
ssk by Associate II
  • 3486 Views
  • 3 replies
Facing issue with LINFLEX_0: Help needed
Posted on April 23, 2015 at 17:36Hi,I am writing a LINFLEX_0 driver for SPC560B60L3. DMA is not used as of now. All interrupts are disabled.Linflex_0 can be configured in 2 sets of port pins set 1: LIN0TX in PB[0] and LIN0RX in PB[1]. Alternate func...
saswatkd by Associate II
  • 2070 Views
  • 3 replies
Resolved! [solved] Interrupt priorities
Posted on November 25, 2014 at 13:18Hello, Yesterday, I investigated a problem with my software project for an SPC560B. There are several calculations running on the controller and it additionally communicates over UART with a PC. When I tried to in...
Patriks by Senior
  • 4161 Views
  • 16 replies
SPC5Studio Login information
Posted on April 15, 2015 at 08:00I am using SPC5Studio with SPC560D MCU for a long time. From couple of days back, when I start the SPC5Studio application it asks for the login information (user name and password) for three different urls. Please fi...
ssk by Associate II
  • 2227 Views
  • 5 replies
Warning-Unknown break cause !!!
Posted on April 17, 2015 at 10:55Hello,I am trying to execute a simple serial driver application on my target board. It uses SPC560D30L3 MCU. I have tested the same code using SPC Discovery kit (SPC560D30L3) mounted on it. The code executes successf...
ssk by Associate II
  • 1524 Views
SPC560Dxx FlexCAN Transmit error
Posted on April 09, 2015 at 12:22I am using SPC560D-DIS Discovery board for development and SPC5 studio.I have imported test application 'SPC560Dxx OS-Less CAN Test Application for Discovery' for FlexCAN testing. In this FlexCAN0 is used in loop bac...
megha2 by Associate
  • 1623 Views
  • 3 replies
unable to debug using SPC5-UDESTK
Posted on April 08, 2015 at 09:33Hi there,I am trying to run a test application (SPC560Bxx OS-Less test application) on SPC560B60L5 mounted in SPC560BADAPT144S evaluation board, using SPC5-UDESTK.After generating and building the test application I ...
gilad2 by Associate II
  • 1850 Views
  • 3 replies
