Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Resolved! SPC560B CAN example config.
Hello Fellow,I'm working with  SPC560B-DIS and loaded the example but I couldn't find where the PIN configuration for the CAN ( for flexcan_0), please let me know where can I find those?
NSood.1 by Associate
  • 1344 Views
  • 1 replies
  • 1 kudos
Resolved! spc560 user manual
Hi All,Please share the link to download user manual for the SPC560 controller.I have searched in ST site, I didnt find it.Thanks,
Resolved! how can i programming uart interrupt(sd_lld_read)?
hello,I am using the SPC582b and SPC5stdio.I want to have interrupts run whenever I receive data.But This function is difficult because it waits until input is received (sd_lld_read, &lcd_data[bit], 1)How can I implement an uart interrupt?I need your...
BKIM.11 by Associate
  • 1833 Views
  • 1 replies
download.spc5studio.com
Dear All ,SPC5Studio updated components are available (56,57 on 58)more information on http://download.spc5studio.com/New or updated componentsRLA 1.13.0   SPC58xHxx (cut2) :       Header file update       Add support for networking test       Add pa...
Resolved! SPC570Sxx Software Reset
Hi,My setup:SP570S-DISP Demo Board EvaluationuC: SPC570S50E1IDE: SPC5Studio 5.8.1What is the simplest way to implement a reset via software?Is there any SPC5 library function that perform software reset?Thanks,Regards
LeoC by Associate II
  • 1692 Views
Resolved! SPC570Sxx Bootloader: Check valid application
Hi,My setup:SP570S-DISP Demo Board EvaluationuC: SPC570S50E1IDE: SPC5Studio 5.8.1I'm using example "SPC570Sxx_RLA Bootloader Application for Discovery".Function "updater_jump()" In "firmware_updater.c" file, jump to application image without checking...
  • 1725 Views
Resolved! SPC570Sxx: Jump to bootloader from application
Hi,My setup:SP570S-DISP Demo Board EvaluationuC: SPC570S50E1IDE: SPC5Studio 5.8.1What is the correct way to jump from application to bootloader?Thanks,regards
  • 1776 Views
  • 3 replies
Resolved! SPC5 interfacing with NAND
Hi All,is there any mcu in SPC5 family with interface for unmanaged raw NAND chips, e. g. External Bus Interface or something else? I've checked modern gen. datasheets and haven't found any mentions about NAND. Thanks for any help
pbori.1 by Associate
  • 1149 Views
  • 1 replies
