AVAS - how to load an audio file with OpenOCD
Max VIZZINI
autodevkit hashtagavas hashtagopenocd hashtagmcu hashtagspc5 hashtagembedded hashtagautomotive
Here you are a quick guide to help you load the audio file in AEK-AUD-C1D9031 Avas board using the AEK-MCU-SPC5LNK programmer.
AEK-AUD-C1D9031 - https://lnkd.in/gP7YkkZd
AEK-MCU-SPC5LNK - https://lnkd.in/gB8CwvxV
AEKD-STEREOAVAS - https://lnkd.in/gqNSxTwg
Thank you Simone Romeo!
1 REPLY 1
markmills
connect the board to the programmer, configure OpenOCD for your setup, and use the appropriate flash_write or program command to upload the file. Refer to the provided documentation links for detailed instructions.
