Synchronous Slave SAI Sub-block Clock Source
Mohamed Jallouli_2
Posted on July 20, 2017 at 14:13
Hello Community,
Does the SAI sub-block clock source matter when it is in Synchronous Slave mode with the other sub-block? In other words, should the two sub-blocks have the same clock source?
Thank you.
1 REPLY 1
bendkhilarwa
Posted on September 23, 2017 at 21:10
To use two block SAI working synchronously, you need to configure the first block as an asynchronous master and the other one as a synchronous slave. Then, The two blocks will share the FS ,BCLK and MCLK lines. And each one will have its own data line.
