STA350BW 2ch downmix to 1ch (Mono)
florian2
Posted on January 20, 2014 at 09:00
in AP-Workbench and Datasheet, i did not found any Switch to generate ''Mono'' from 2-channel Input, with STA350BW
Would this be possible using the PEQ?
Thank you
best regards,
Florian Breu
#mono-downmix-sta350bw #apworkbench-forum
2 REPLIES 2
Anthony BOIMOND
Posted on January 21, 2014 at 11:35
Hello Florian,
A new forum dedicated to APWorkbench has been created.
You can find it here:
[DEAD LINK /public/STe2ecommunities/analog/Lists/APWorkbench/AllItems.aspx]https://my.st.com/public/STe2ecommunities/analog/Lists/APWorkbench/AllItems.aspx
Could you please create a new post in this forum and simply copy/paste your question in it?
The audio team will support you.
Best regards,
Anthony
Nickname1623_O
Posted on February 18, 2014 at 07:05
hi Florian,
you can select output configuration mode in 0x05 hex register , for mono output , OCFG bits should be 11. then channel 1 and 2 had been mixed to channel 3 .
thanks
