2014-01-20 12:00 AM
in AP-Workbench and Datasheet, i did not found any Switch to generate ''Mono'' from 2-channel Input, with STA350BW Would this be possible using the PEQ? Thank you best regards, Florian Breu #mono-downmix-sta350bw #apworkbench-forum2014-01-21 2:35 AM
Hello Florian,
A new forum dedicated to APWorkbench has been created.You can find it here:[DEAD LINK /public/STe2ecommunities/analog/Lists/APWorkbench/AllItems.aspx]https://my.st.com/public/STe2ecommunities/analog/Lists/APWorkbench/AllItems.aspxCould you please create a new post in this forum and simply copy/paste your question in it?The audio team will support you.Best regards,Anthony2014-02-17 10:05 PM
hi Florian,
you can select output configuration mode in 0x05 hex register , for mono output , OCFG bits should be 11. then channel 1 and 2 had been mixed to channel 3 . thanks
