Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
marking 2L28I
Posted on November 04, 2013 at 09:54I found an IC,marking 2L28I,manufactured by ST? I want to know it,s order number. #marking-brand
yuegang by Associate
  • 1297 Views
Configuration, set-up or help files for APWorkbench with MEMS
Posted on September 30, 2013 at 15:53Are there any example apc files for the MEMS microphone demonstrator? as indicated in the application note: AP4146, For example basic directional microphone set-up. There seems to be no Help available or very lit...
jmoore by Associate
  • 821 Views
  • 1 replies
Availability of RHF801
Posted on September 12, 2013 at 18:05JPL has been considering usage of this high speed radiation hardened comparator for a space application.  The product was announced with a target specification.  However, a final specification nor DLA drawing has...
mark2 by Associate
  • 802 Views
  • 1 replies
PCB Footprint for amplifiers
Posted on July 26, 2013 at 14:45Hi guys,I'm currently working with TSX562IQ2T in DFN8 package.Do you have some kind of recommended footprint for this package? #package-footprint #qfn #dfn
38josa by Associate
  • 1171 Views
Is the TSC1021 capable of measuring negative voltage?D
Posted on July 10, 2013 at 23:19HiI read the datasheet of the TSC1021, but it is not clear if the IC is protected from negative voltage in the Vp/Vn terminals, or cant it measure the current.I need to measure current of negative voltage, and plannin...
avishai by Associate
  • 1263 Views
  • 3 replies
