2013-07-24 11:48 PM
hi form members,
I am using audio amp. (TDA7575B) which has differential input (IN1+,IN1-) but in our case I have single ended input only from my codec, so i planned to connect IN1- pin to ground with a series capacitor. Is that OK else you have any specific recommendation please answer at the earliest. REGARDS, BALA2014-02-14 04:20 AM
Hello Bala,
This forum is dedicated to operational amplifiers, comparators and current sensing products. In order to be more efficient with appropriate answers, another e2e forum has been created for audio amplifiers. In order to have an accurate answer by our audio support team, would it be possible to copy/paste your question to the related forum please ? Here is the hyperlink shortcut :https://my.st.com/public/STe2ecommunities/analog/Lists/Audio%20Amplifiers/AllItems.aspx
Sorry for the inconvenience. Best regards, Sylvain2014-02-17 07:48 PM
hi Bala,
yes , you can ground IN- through a coupling capacitor. but the value should be same with coupling capacitor for IN+. thanks .
