2016-03-30 9:19 AM
I'd like to know if the STL62P3LLH6 P-channel MOSFET's Safe Operating Area chart is correct in
http://www.st.com/web/en/resource/technical/document/datasheet/DM00105886.pdf
. I have been comparing these charts of various other parts, specifically the ID value at VDS = 20V and a 100ms pulse width. This part shows an ID of ~20A at this location. However, I've found no other parts with a value this high in a PowerFLAT package (or similar). All other parts with a value this high are DPAK (or similar, with a ~3x lower thermal resistance), and are quite a bit more expensive (>4x). I'd like to ask if this is a datasheet mistake or a very good deal. If I'm making a mistake reading the datasheet please let me know. Thanks!2016-03-30 11:22 PM
I'm sorry but this power MOSFET is not part of signal condiioning products. I recommended you to contact the/onlinesupport/app?page=onlineSupport
Another possibility would be to post your question in Sorry for this redirection. Regards, Sylvain2016-03-31 6:27 AM
The online support has never worked for me. I always get a ''Serena Single Sign On Invalid User ID or Password.''error when I try to access it which is why I post questions on the forum instead. Thank you for your suggestion though - I will post there instead. Thanks!
