Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
hi im working on FDA903D AEK AUD D903V1 autodevkit, im trying to send information from an NXP MPCU5748G microcontroller through I2C AND I2S.
i have set enables 1,2,3 and 4 as 1100 which is address 2 , but for some reason the speaker is not open and voltage is not passing through it which means i cant move on and give orders through i2c registers, can you please explain what the reason mig...
aturk.2 by Associate II
  • 834 Views
  • 0 replies
Thermal Model for TDA7803A
Needed Detailed Thermal Model for TDA7803A which includes Die, Solder balls etc., and their material properties for thermal simulation
How To call a function in c++
Hi, I recovered a program and I would like to use but I do not understand very well. Could you give me some info. Thank you for your helps Regards
DYann.1 by Senior II
  • 936 Views
Hi Team, we have two products with the TS4984 BTL amplifier designed in. We would like to mix the signals at the output stage into a single 8 Ohm speaker.
Is it possible to operate 2 x TS4984 amplifier as a PBTL only using the Left channel from each product. (Both products share the same power domain)We have prototyped a small interface consisting of 4 x 100uF non-polarized capacitors to mix the differ...
DHadd.1 by Associate II
  • 1263 Views
  • 4 replies
SGTL 5000
Hello, I would like to know how to communicate a CODEC SGTL 5000 with STM32 ? Do you know where I can find the the library (.C and .h) of this component ? Thank you for your helps. Regards
  • 1499 Views
  • 3 replies
