Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
STA540 ?
Good afternoon....I am looking into using an STA540 in a power amp design for a single supply 4 ohm speaker. Other than the datasheet there seems to be no reference design material on how to use this chip. I have found Sparkfun has a reference desi...
SWenn.1 by Senior III
  • 636 Views
  • 0 replies
Request technical information for Reference : TSB7192AIST
Hello, I send you this message to ask you to provide me, if possible, the information below- RoHS II Status : Yes, with exemption, No- J-STD-020 Moisture Sensitivity Level Rating (MSL)- Termination Plating Finish- Quantity of parts in a packaging ( R...
AIcha.1 by Associate
  • 921 Views
  • 1 replies
STuW81300 I designed a device with STuW81300. PLL locked. I received output power like in the datasheet. Okay. But when I measured the output signal, I saw a lot of spurs. I don't know how to improve my signal. Do you give me support about this spur?
STuW81300I designed a device with STuW81300. PLL locked. I received output power like in the datasheet. Okay. But when I measured the output signal, I saw a lot of spurs. I don't know how to improve my signal. Do you give me support about this spur? ...
STuW81300 RF Output power is lower than expected.
I am using the STuW81300 as LO generator to generate 12GHz LO. Although I am able to get the frequency out correctly and the PLL is also locking the output power of the signal us at -39dBm (probing) where ideally it should be giving close to -4dBm. T...
JJose.6 by Associate
  • 933 Views
  • 0 replies
