stm8, cpu register, cosmic
MykolaLevun
Hello
How can I access CPU registers using the Cosmic compiler?
For example, when I access register A, the compiler throws an error A is undefined (This is shown in the picture and also the project files).
Ans
You've to define address for any register. Check datasheet and see what's the address of A register and then define it accordingly.
Checkout this guide: https://lujji.github.io/blog/bare-metal-programming-stm8/
2 REPLIES 2
Ans
SofLit
If "A" is a an internal core register you need to access it in assembly language.
If "A" is a peripheral register you need to define the address of "A" and access it by pointer in C.
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
