Is it possible to set different EXTI trigger condition at same port ?
jeffrey23
Posted on May 15, 2010 at 04:29
4 REPLIES 4
brazov22
Posted on May 17, 2011 at 15:08
no it's not possible. Configuration refers to the whole port.
brazov
jeffrey23
In STM8S103F3, I used both PC.3 and PC.6 as falling edge trigger source.
But how to distinguish them during EXTI_PORTC_ISR (IRQ5 interrupt service routine) ?
dhutchison1945
You must enable both falling and rising edge on that port.
And after you must discriminate every interrupt on that port with an xor manually
It's complicated but this is the way.
b.r.
Spectre
jeffrey23
Hi Spectre,
Thanks for your input.
Is there an easier way ?
However, I got a solution finally.
