Error configuring STVD to use cosmic compiler
kvest
Posted on May 17, 2010 at 18:09
hsynenko
Posted on May 17, 2011 at 15:08
Hi vest.kyle,
I had similar problem. I do not know how accurate a solution, but it worked for me...
You must make the choice to toolchain while create a new workspace. Problem does not occur choice when starting project. I hope it will be help. I dont know what is root cause. if you can know, Can you share me?
