Is it necessary to set FLASH_CR2 while programming EEPROM ?
Options
2010-05-14 1:39 AM
Posted on May 14, 2010 at 10:39
Options
2011-05-17 6:08 AM
Posted on May 17, 2011 at 15:08
Hi Boltnut,
if you want to program eeprom by word (this means 4 bytes in one shot thus minimizing the programming time) you need to set WPRG. Otherwise if you want to program eeprom by byte you don't need to set any configuration bit.
brazov
