how to read the .map file
Options
‎2010-12-02 1:46 AM
Posted on December 02, 2010 at 10:46
3 REPLIES 3
Options
‎2011-05-17 6:11 AM
Posted on May 17, 2011 at 15:11
On Win-XP, In my installation, I have a 'Cosmic Tools' entry under Start > All Programs.
If you can find that, then look at Cosmic Tools > STM8 16K Compiler > Manuals > Cross Compiler User's Guide It's C:\Program Files\COSMIC\CXSTM8_16K\Docs\CXSTM8_UsersGuide.pdf in my installation. Then just search for ''.const'' or whatever in the PDF... Simples!Options
‎2011-05-17 6:11 AM
Posted on May 17, 2011 at 15:11 Hi, the user manual is in the /doc subdirectory of every compiler installed. As it has been suggested, look in there for the answer to your question; however, as a quick overview:.const constants .text code .data initilized data (RAM) with 16 bit address .bss non-initilized data (RAM) with 16 bit address .bsct initilized data (RAM) with 8 bit address (page0) .ubsct non-initilized data (RAM) with 8 bit address (page0) Hope it helps. Regards, Luca
Options
‎2011-05-17 6:11 AM
Duh :) Thank you!
