section boundary crossing
saranyim
Posted on November 30, 2010 at 08:04
saranyim
Posted on May 17, 2011 at 15:11
Thank you Luca but could you please guide me how to do that?
I use STVD + Cosmic (CX STM8) and using firmware libraries from ST
I looked in menu Tools -> Setting in C Compiler tab and made change on Memory model  to Long Stack(+modsl0)
if I use short stack I have problem with zero page oversize.
I look around in the forum I found some that point to change to >64k model but I could not find that setting,
Saran
luca239955_stm1_st
Senior II
you must compile your application with a ''>64k'' memory model (one of those that do not end with ''0'') and matching libraries.
Luca
saranyim
Found the solution!!
When select +modsl will generate the error ''f__stext not defined''
then go to stm8s_it.h line number 35
look for ''void _stext(void); /* RESET startup routine */''
and edit to ''
extern @ near void _stext ();''
 then problem solve
