how to disable IWDG during run time
sivainvitesu
Posted on October 01, 2010 at 07:59
Hi all,
i need to disable the independent watchdog during runtime. (after it was started once).
what is the way for this.
also i am using LSI as my MASTER clock source.
#iwdg
1 REPLY 1
Andrew Neil
Evangelist III
Posted on October 03, 2010 at 22:35
''i need (sic?) to disable the independent watchdog''
Why do you (think you) ''need'' (sic?) to disable it?
''after it was started once''
Why did you start it if you don't want it?
