2010-09-30 10:59 PM
Hi all,
i need to disable the independent watchdog during runtime. (after it was started once). what is the way for this. also i am using LSI as my MASTER clock source. #iwdg2010-10-03 1:35 PM
''i need (sic?) to disable the independent watchdog''
Why do you (think you) ''need'' (sic?) to disable it?''after it was started once'' Why did you start it if you don't want it?
