2020-06-09 07:40 PM
Hi. I'm using STVD v 4.3.12 with an STMTL52F4 MCU. Debug building works just fine. However, when I switch over to a Release build (changing nothing else), it fails to compile, reporting that it can't open an include file it was able to find before. Can anyone tell me why that is the case? The include path showing under both Debug and Release versions under Settings->General is showing as Hstm8. Thanks.
