Which cube programmer version support jlink
‎2024-04-16 6:38 AM
Hi ST,
can you please look into this link STM32CubeProgrammer & STM32CubeMonitor support SEGGER's J-Links
and let us know which version of the cube programmer support jlink.
A.Satt
STM32CubeProgrammer
‎2024-04-16 11:41 AM
There should be the option J-LINK behind the turquoise drop down button, per default showing ST-LINK:
‎2024-04-16 7:02 AM - edited ‎2024-04-16 7:03 AM
i just downloaded CubeProgrammer , newest version , 2.16.0.
and can select J-Link now :
‎2024-04-16 7:09 AM
J-LINK is supported since CubeProgrammer 2.16.0 and CubeMonitor 1.8.0.
Does it answer your question?
/Peter
‎2024-04-16 11:25 AM
Hi
Thank you very much for your immediate reply. I have version 2.16.0. But there is no J-link supported in it. Drop down manue does not show j-link.
regards
A.SATT
‎2024-04-16 11:33 AM
Hi Peter,
I just downloaded the new version. But it did not help as well. There is no option to select J-link. I have windows 11 Home edition installed. Can you please look into this. I had old version installed and i also updated directly from the old version that also did not help. I think something is wrong with installation file.
‎2024-04-16 11:43 AM
Hi Peter,
Thank you very much there it is. I missed that option.
