stm32u5 cube programmer fail to download without full chip erase
‎2023-06-29 7:25 AM
I want to write firmware to stm32u575 using cube programmer, but when I do download from the erase & programming section, it fails to write.
Of course, I have turned off the "skip flash erase before programming" checkbox.
However, if I run the program in automatic mode with the "full chip erase" checkbox checked, it writes successfully.
With the L4 and G4 that I have used in the past, I was able to write successfully in both cases, but with the U5, it fails.
When I use the U5, I use cube programmer.dll to perform full chip erase before downloading.
,Has this behavior changed since the writing of u5 microcontrollers in the specifications?
I have confirmed that the option byte is factory default.
STM32CubeProgrammer
‎2023-06-30 2:48 AM
Hello @junichi ohashi
Could you please share the log? Are you flashing secure firmware? It is possible that the firmware needs to erase/reset the chip before programing the flash.
‎2023-07-14 1:31 AM
sorry.
this problem source is by my circuit design cause there was no problem encounted in stm32 nucleo u575zi-q.
I will look into the cause now.
‎2024-06-27 2:12 PM
@junichi ohashi , were you able to determine the root cause? I am seeing a similar issue but I can only reproduce it on my board and not on the dev kit
‎2024-06-27 8:55 PM
sorry, I haven't found a fundamental solution.
