2019-03-16 10:19 AM
The problem I´m experiencing is already "fixed":
https://community.st.com/s/question/0D50X00009q2bdeSAA/solved-problem-running-stm32cubeprogrammer
When running the program STM32CubeProgrammer, an error message appears, saying:
"CubeProgrammer_API or one of its dependencies is missing. Please try reinstalling the program of check your java architecture"
STM32CubeProgrammer is in verison 2.0.0 now.
Any idea?
2019-03-17 09:30 AM
2019-03-16 01:42 PM
And you've done what exactly to fix or clean up your Java installation? You've not provide any details about what's actually installed on your system to be able to debug or diagnose the issue. What does the Java control panel show as being installed?
2019-03-17 09:30 AM
Sorry, my bad, it works just fine.
A reset was enough 🙏
