2024-12-19 2:03 PM
I found a bug on new version 2.18 STM32Cube programmer.
Of course, I have the same problem with the new version of STM32CubeIde 1.17
It looks file STM32_Prog_DB_0x483.xml in \Data_Base folder has changed between versions 2.17 and 2.18
If I use the file STM32_Prog_DB_0x483.xml from the version 2.17 and I replace this file in version 2.18, I can access my STM32H730 device.
We tried it on 2 different computers.
I do not really understand the xml file differences, so I do not know if I can continue to use STM32_Prog_DB_0x483.xml file of version 2.17 with version 2.18 and STM32CubeIDE 1.17
Do you have a workaround ?
Sébastien
2025-01-10 1:40 AM
Hi @Maryem
Do you have any feedback of this problem.
I just looking for a workaround right now.
I cannot develop my firmware for almost 1 month now.
Sébastien
2025-01-20 7:57 AM
Hello @COSEBE ,
I've sent you a message. Could you check your DM?
Maryem.
2025-01-20 7:58 AM
Yes, DM is answered
2025-01-28 12:52 AM
2025-02-10 5:54 PM
I Have the same problem. How to get the patch and how to install it?
2025-02-24 9:08 PM
Hi Maryem,
I too have a custom board with this issue on this chip. I have upgraded to STM32CubeProgrammer 2.18 and upgraded my STLink V2. I cannot program via STM32cubeIDE as well, but can read target info on CubeProgrammer. Essentially the same as the original post.
What is the fix??
