Program STM32G071 from Raspberry Pi
PNada.1
Is it possible to program a STM32G071 from a raspberry pi running Raspbian OS? Is there a USB to serial driver for this?
4 REPLIES 4
If you're using an ST-Link to program, STM32CubeProgrammer should work on Linux.
If you're programming using the ROM UART bootloader, you'll need a usb to serial cable.
PNada.1
So the linux installer is compatible with Raspbian OS? I saw there were two linux installers available-- Debian and generic linux. The SBC being considered is RPi 4. I will have to find out if the Debian installer will work on it.
Thank you,
Priya
I assumed Raspian was linux-based. Not that familiar with it.
Maxime_BELAVAL
Thank you for your patience, we know this has been a long-awaited request!
We're happy to share that Raspberry Pi support for STM32CubeProgrammer will be available in June 2026 with version 2.23.
Please refer to this Developer News for more information: [Coming June 2026] Raspberry Pi support for STM32CubeProgrammer
We also encourage you to share your feedback with us by commenting on the Dev News, as it helps us prioritize future improvements and developments.
Thank you all,
Max
