2024-04-10 08:23 PM
I tried to connect but it's always: "No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication"
I also try "Under reset" mode but still not working.
Can someone help me
2024-04-11 12:32 AM - edited 2024-04-11 12:43 AM
Sorry this is neither ST’s board (blue pill most probably with a contrefit chip) nor an ST’s ST-link (copied ST-Link), I cannot help you.
2024-04-10 08:55 PM
Are using a USB data cable or charging cable?
2024-04-10 08:55 PM
Show a schematic
Error suggests chipsnis not powered or connected correctly.
Make sure the ST-LINK gets the VTarget power from the board.
2024-04-10 09:00 PM
I used USB data cable
2024-04-10 09:03 PM
I think i connected correct
2024-04-10 09:04 PM
What is the board are you using? ST board? Custom board?
Check the power supply of the MCU.
ST-Link firmware updated?
2024-04-10 09:11 PM
ST board i think
I updated ST-Link firmware
I don't know how to check the power supply, sorry
2024-04-10 09:20 PM
Provide a picture of you setup: your board, the cable connection…
2024-04-10 11:25 PM - edited 2024-04-10 11:28 PM
Sorry for late response
