How to flash the application's binary file to STM32L4R5ZI MCU through UART using STM32 Cube programmer?
Shilpashree Madhu
Peter BENSCH
AN2606 describes this process for the STM32L4R in section 65. The bootloader can be activated using pattern 6 (section 4.1), which describes the possibilities for activation.
Good luck!
/Peter
<edit>As I've just seen, you've essentially asked the same question.</edit>
Peter BENSCH
Good luck!
/Peter
Shilpashree Madhu
Thank you Sir..
