SYS settings not available for Boot and Application context
Intector
Hey guys,
Why are the "SYS" settings simultaneously unavailable for Boot and Application? There may be a reason, but it's somewhat unclear.
Thank you, and as always:
"Always be yourself unless you can be a pirate. Then always be a pirate."
1 REPLY 1
STTwo-32
Hello @Intector
Infact, there is not an issue on that. The SYS setting is dedicated only to set the timebase source. So, there is not any other parameter to configure.
Best Regards.
STTwo-32
