STM34CubeMX does not start
perbaecklund9
Posted on October 20, 2014 at 11:39
I had CubeMX installed and working fine. Then I updated the application and now all I see is dialog flashing by the says ''Check files''. After that nothing happens.
When I start it from a DOS box I get:
java -jar STM32CubeMX.exe
HeapMemory: 16252928
Using Application install path:C:\Program Files\STMicroelectronics\STM32Cube\STM
32CubeMX
32CubeMX
loadPluginJar : clock
loadPluginJar : add clock
loadPluginJar : filemanager
loadPluginJar : add filemanager
loadPluginJar : ipmanager
loadPluginJar : add ipmanager
loadPluginJar : pinoutconfig
InternalPropertyChange: ChangeKeepUser  dont care
loadPluginJar : add pinoutconfig
loadPluginJar : power
loadPluginJar : add power
loadPluginJar : projectmanager
This is Windows
This is 32 Bit VM
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeMX\\db\plugins\projectman
ager\windows\32\toolgen.dll
loadPluginJar : add projectmanager
loadPluginJar : updater
32CubeMX
STM32CubeMX Software Update Start Now
I have reinstalled the program with the same result.
Suggestions?
#stmcube-stmcubemx-cube-stm32cube
9 REPLIES 9
kolomaznik
Posted on October 20, 2014 at 12:06
I have the same problem.
yevgen
Posted on October 21, 2014 at 08:46
Hi !
I have the same problem on Windows7 & 8 64bits with clean and update installation of CubeMx.
What can be problem ?
DUrbano
Posted on October 21, 2014 at 12:01
I have same problem and I don't understand why...
sdim
Posted on October 22, 2014 at 15:28
I also have the same problem.
DUrbano
Posted on October 22, 2014 at 17:10
I tried this: in my documents folder I found an .stm32cube folder and I deleted it. Re-installed last version of CubeMX and works fine (till now)
perbaecklund9
Posted on October 23, 2014 at 12:39
Thank you!
That helped.
kolomaznik
Posted on October 23, 2014 at 13:26
It helped
me
also
stm32cube-t
Senior III
Posted on November 19, 2014 at 15:33
Can you please indicate which version you started from and which version you upgraded to.
Thank you.
qwer.asdf
Posted on November 19, 2014 at 16:27
I had this problem when updating from 4.3 to 4.4. The update from 4.4 to 4.5 today was OK.
