Stm32h7 Ethernet
Raja_Kaaliraj
Hi, I am frequently getting tired while working with the STM32H743ZIT6 144-pin Nucleo board / STM32H743IIT6 controller board and an externally connected Ethernet module using a communication protocol. Despite trying many different ways, it is still not working. The Ethernet module cannot be pinged.
I’ve tried older versions of STM32CubeMX, including 5.0.0, 5.4.0, 6.10.0, and 6.11.1, as well as older firmware versions, but it still isn’t working.
I have only used the Keil MDK-ARM V5 toolchain.
Can anyone please help me with this communication protocol? If anyone has worked with the controllers I mentioned above, could you please share your code? Thank you!
So the Generative AI not working?
Sir, I couldn't understand your message. Please explain, sir.
