stm32f769i-disco + FreeRTOS + Lwip + CubeMX: is it possible to produce an .ioc configuration with working ethernet?
redmig
Does somebody can provide a cubeMX generated file with working ethernet and freeRtos?? Is it even possible? I know there is a working example application but it is not from CubeMX. Using the new HAL eth driver from the F7 package I am not able to even get a ping reply..
Thanks all
redmig
A first issue is with newlib (https://nadler.com/embedded/newlibAndFreeRTOS.html).
The calls to rand() function used to initialize lwip hang.
This seems to be a problem the FreeRTOS distributed by ST. Here the bug report: https://community.st.com/s/question/0D50X0000BB1eL7SQJ/bug-cubemx-freertos-projects-corrupt-memory
Still after "fixing" it I have no network..
