STM32F7 ADC + DMA + multiples channels + regular conversion + continuous conversion not sampling
‎2022-06-01 7:26 AM
I want to sample 9 channels with 1 ADC, using DMA in circular buffer mode with continuous conversion.
My callbacks of conversion (like HAL_ADC_ConvCpltCallback or HAL_ADC_ConvHalfCpltCallback) are not triggering, the sampling seems to never start.
I'm also using freeRTOS.
Am I missing something ?
Here's the code:
#define ADC3_BUF_LEN 9
uint16_t adc3_buf[ADC3_BUF_LEN];
/* ADC3 init function */
void MX_ADC3_Init(void)
/* USER CODE BEGIN ADC3_Init 0 */
/* USER CODE END ADC3_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC3_Init 1 */
/* USER CODE END ADC3_Init 1 */
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc3.Instance = ADC3;
hadc3.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
hadc3.Init.Resolution = ADC_RESOLUTION_12B;
hadc3.Init.ScanConvMode = ADC_SCAN_ENABLE;
hadc3.Init.ContinuousConvMode = DISABLE;
hadc3.Init.DiscontinuousConvMode = DISABLE;
hadc3.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc3.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc3.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc3.Init.NbrOfConversion = 9;
hadc3.Init.DMAContinuousRequests = ENABLE;
hadc3.Init.EOCSelection = ADC_EOC_SEQ_CONV;
if (HAL_ADC_Init(&hadc3) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_9;
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
if (HAL_ADC_ConfigChannel(&hadc3, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_14;
sConfig.Rank = ADC_REGULAR_RANK_2;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_15;
sConfig.Rank = ADC_REGULAR_RANK_3;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_4;
sConfig.Rank = ADC_REGULAR_RANK_4;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_10;
sConfig.Rank = ADC_REGULAR_RANK_5;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_11;
sConfig.Rank = ADC_REGULAR_RANK_6;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_12;
sConfig.Rank = ADC_REGULAR_RANK_7;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_13;
sConfig.Rank = ADC_REGULAR_RANK_8;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_3;
sConfig.Rank = ADC_REGULAR_RANK_9;
Error_Handler();
/* USER CODE BEGIN ADC3_Init 2 */
if (HAL_ADC_Start_DMA(&hadc3, (uint32_t*)adc3_buf, ADC3_BUF_LEN) != HAL_OK)
Error_Handler();
/* USER CODE END ADC3_Init 2 */
Thank!
- Labels:
ADC
DMA
STM32CubeMX
STM32F7 Series
‎2022-06-03 12:48 AM
Found the culprit. The init (done by CubeMX) should have DMA init before the ADC.
MX_DMA_Init();
MX_ADC3_Init();
To change the init generation go to MX editor, Project Manager > Advanced Settings > Generated Function Calls and move the ADC init under the DMA init
MX_DMA_Init();
MX_ADC3_Init();
