STM32cubeMX v4.27.0 crashes when "Generate Code" is clicked when creating a new project.
2018-09-23 2:41 PM
The pc is win10-64bit, I do not have this problem in win7-64. The STM32cubeMX GUI can only be closed in Task Manager where java JRE is reported as "Suspended". Windows java application logs indicate "hangup", timestamped to when I do the clicking. JRE 1.8.181-64bit is installed.
Any advice would be appreciated.
STM32CubeMX
2018-09-24 7:37 AM
Hello @CS.3uydam ,
Please share your ioc file for check and reproduce your case.
Kind Regards,
Imen
Imen
2018-09-27 2:56 PM
2018-10-25 1:34 AM
Hello csuydam1.5370555733257861E12
Could you please share your CubeMX log, unfortunately I could not reproduce from my side
You can found your log under your "user folder"/.stm32cubemx
2018-10-25 1:41 AM
I had the similar issue this week, creating a new L4R5 project. It took forever,
like Java was updating something...
I found that you must let it run, maybe 30minutes..
2018-10-25 2:06 AM
Oddly, another user this morning contacted me and said he had the same problem, but left it alone for a half hour and it completed. Needless to say, if true, that is not an acceptable workaround.
2018-12-05 1:41 PM
Dear Mr. Gharbi,
I tried the STM32cube v5 and experienced the same freeze-up and "Suspended" java error message. I guess the log I sent you revealed nothing. Is there any other methodology we can employ to isolate this problem?
Thanks, csuydam
2018-12-06 12:06 AM
Hi @CS.3uydam
Sorry but I did'nt receive the log could you attach it or send it by message please
you can find your log under c:\users\login\.stm32cubemx\STM32CubeMX.log.
2018-12-06 5:05 AM
2018-12-06 11:33 AM
