2021-11-24 05:13 AM
It's not that disturbing and obviously it doesn't prevent anyone from using it, but it's years that you have "Search (Crtl+F)" instead of Ctrl in every search box.😅
2021-11-24 05:31 AM
Well spotted, thanks for the hint!
I actually never noticed it either, probably because it's light gray and you can't see it anymore after typing in the first character.
So far I could only find it in the configuration windows, where you can search for parameters, constants etc. Are there any more?
/Peter
2021-11-24 05:43 AM
Yes it's in all those configuration menus, and also in Project Manager!
I don't know if the search box appears elsewhere but I bet it's the same wherever it's found.
You're welcome!
2021-11-24 05:53 AM
Thanks again! We will check this and of course change it in one of the next versions.
@Amel NASRI Please forward this topic to the STM32CubeMX team.
/Peter
2021-11-24 11:40 PM
Hello @Community member ,
Thanks for raising this issue to our attention.
I confirm the problem and it will be fixed 🙂
Khouloud
