STM32CubeMx much not edititable gray field
maniek
what happened last time (2 years.-) ? why can't I change a lot of things ?
I am working on CubeMx for STM32H745ZITx ...
I have loaded default project for Nucleo-144 STM32H745ZITx, and want to customise for me unfortunately many options are grey ... are not editable ....?
5 REPLIES 5
STTwo-32
Hello @maniek
To understand why an option is grayed you can put the cursor on the grayed option and you will have details about why you can't use it.
Best Regards.
STTwo-32
hello STTwo-32,
would be so easy I would not write .....
- project location is grey fix why ?
- I want to switch off Cotex-M4 to a large extent, does not work .... (does not say can remove ...)
no one has an idea ?
but it must be something fundamental ....
Gruss
maniek
Can you add your.ioc file so i can check this.
Best Regards.
STTwo-32
see attach ....
