STM32CubeMX fails to generate normal files
‎2023-03-02 4:40 AM
Yesterday I was able to generate code normally using STM32CubeMX. But today I am generating code again using STM32CubeMX with a lot of undefined code. I sent the file to a friend and found that he generated the code once again using STM32CubeMX and it worked. But my computer still can't generate normal code again.
- Labels:
STM32CubeMX
STM32F1 Series
‎2023-03-03 3:51 AM
The version is 6.5.0, I reinstalled it three times, the first and second time still had problems, the second time suddenly it was fine.
‎2023-03-02 4:13 PM
Please show the very first error/warning message.
‎2023-03-02 5:00 PM
Every error is the same
‎2023-03-02 5:32 PM
The circled part in the first picture is not in my cubemx production file
‎2023-03-03 3:16 AM
Hello 风æ£è±ª.1,
Thanks for sharing this issue.
To further analyze your problem could you please provide:
- The CubeMx and MDK-ARM versions
- The project you are working on or your *.ioc file if it is possible
Kind regards,
Aymen
‎2023-03-03 3:51 AM
